Toshiba 4TB Canvio USB 3.0 3.5" Desktop Hard Drive (Black)
Discontinued, only used stock available
Key features
  • Portable peace of mind
  • Extra hard drive protection
  • High-capacity storage
  • A stylish design
  • Faster transfer speeds
  • Cloud backup capabilities
Product codes
Documents
SMART. SAFE. SPEEDY.
The STOR.E CANVIO Desktop is the smart, speedy way to preserve your favourite files and memories. USB 3.0 makes it super-fast, and it`s backwards compatible so connecting to USB 2.0 devices is no problem. The pre-loaded NTI® Backup Now EZ™ software is a complete back-up solution to keep your files safe. And password protection goes the extra mile to guard against intruders. The CANVIO DESKTOP is the ideal partner for your TV or PC.
Powered by new USB 3.0 technology, these portable hard drives are far faster than--but still compatible with--USB 2.0 technology. That's important for speedy transfer when organising your files.
These hard drives are easy to carry and nice to look at. You get a choice of colours and versatile mounting options. Available in several capacity sizes, STOR.E CANVIO desktop hard drives are perfect for storing data, music, pictures, and more.
These hard drives come with pre-loaded backup software that provides file, folder, and full system backup and recovery. Password encryption keeps unauthorised users from accessing your valuable data.
  • Interface: USB 3.0 (USB 2.0 compatible)
  • Speed: 7200 rpm (4 TB, 5 TB)
  • Average seek time: 10.5 ms (4 TB, 5 TB)
  • Cache buffer: 32 MB
  • Capacity: 4 TB- File system: NTFS (MS® Windows) *The drive can be re-formatted to HFS+ file system for full Mac compatibility.
  • Power: AC Power adapter cable, Input: 100 - 240 V, 650 mA, Output: 12 V - 2 A, EU/UK exchangable plug head
  • Weight: Max. 1040 g
  • Backup Software: NTI® Backup Now EZ™
  • System Requirements: Windows® VISTA® / Windows® 7 / Windows 8 / Windows 8.1, Mac OS® X (Tiger®, Leopard®, Snow Leopard®, Lion®, Mountain Lion®) 10 MB system hard disk space, 256 MB system memory, one free port of USB 3.0 or USB 2.0
  • Box Content: STOR.E CANVIO Desktop, NTI® Backup Now EZ™ software (pre-loaded), USB 3.0 cable ("A" to Micro "B" 2.5"), AC adapter cable, Quick Start Guide, User Manual (pre-installed on the hard drive), Warranty Leaflet
Product Description Toshiba StorE Canvio - hard drive - 4 TB - USB 3.0
Type Hard drive - external (desktop) - password authentication, NTFS formatted
Capacity 4 TB
Form Factor 3.5"
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Buffer Size 32 MB
Spindle Speed 7200 rpm
Features Password authentication, NTFS formatted
Power Source Included AC adapter
Enclosure Colour Matte black
Dimensions (WxDxH) 4.2 cm x 12.9 cm x 16.7 cm
Localisation United Kingdom
Resources
The following resources are available for the Toshiba 4TB Canvio USB 3.0 3.5" Desktop Hard Drive (Black)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba 4TB Canvio USB...
