Toshiba 500GB Stor.E Basics USB 3.0 2.5" Portable Hard D...
Toshiba 500GB Stor.E Basics USB 3.0 2.5" Portable Hard Drive Black
Key features
  • 6.3cm (2.5") external hard drive
  • SuperSpeed USB 3.0 port
  • Backward compatible with USB 2.0
  • USB powered
  • Silent operation
  • Plug and Play
Product codes
Documents
Quickly transfer files with SuperSpeed USB 3.0 and store up to 500 GB of data on STOR. E BASICS external drives. Easy to use and backward compatible with USB 2.0, STOR. E BASICS external drives are ready to use with no software installation required.
The Toshiba STOR.E Basics 2.5 Inch 500GB external hard drive makes super speed storage simple. Receive high speed storage via the USB 3.0 port, allowing you to store your data with super speed. Enjoy high capacity storage of up to 500GB in a conveniently compact casing.
  • Interface type USB 3.0 (USB 2.0 compatible)
  • Interface Transfer rate max. 5.0 Gbps
  • On-bus power max. 900 mA
  • Dimensions (mm) 118.9 (L) x 79 (W) x 13.5 (H) mm
Box content
  • 500GB STOR.E Basics
  • USB 3.0 cable ("A" to Micro "B")
  • Quick Start Guide
  • Warranty Leaflet
  • pre-installed User Manual
Product Description Toshiba StorE BASICS - hard drive - 500 GB - USB 3.0
Type Hard drive - external (portable)
Capacity 500 GB
Form Factor 2.5"
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features Ramp Load
Power Source USB bus
Enclosure Colour Matte black
Dimensions (WxDxH) 7.9 cm x 11.9 cm x 1.4 cm
Weight 150 g
Designed For Dynabook Toshiba Portégé R830, R930, Z830, Z930; Toshiba Satellite Pro C660, C850, L770, L830, L850, L870; Toshiba Tecra A11, R840, R940, R950; Toshiba LX830; NB510; NB520; Qosmio F750, X770, X870; Satellite C660, C670, C850, C850D, C855, C855D, C870, C870D, C875, C875D, L730, L735, L750, L750D, L755, L755D, L775, L775D, L830, L850, L850D, L855, L855D, L870, L870D, L875, L875D, L950D, L955, L955D, P750, P770, P845T, P850, P855, P870, P875, R830, R930, S70, U840, U840W, U920t, U940, Z830, Z930
Resources
The following resources are available for the Toshiba 500GB Stor.E Basics USB 3.0 2.5" Portable Hard Drive Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
