Toshiba 5TB Canvio USB 3.0 3.5" Desktop Hard Drive (Black)
Key features
  • Portable peace of mind
  • Extra hard drive protection
  • High-capacity storage
  • A stylish design
  • Faster transfer speeds
  • Cloud backup capabilities
Product codes
The STOR.E CANVIO Desktop is the smart, speedy way to preserve your favourite files and memories. USB 3.0 makes it super-fast, and it's backwards compatible so connecting to USB 2.0 devices is no problem. The pre-loaded NTI® Backup Now EZ™ software is a complete back-up solution to keep your files safe. And password encryption goes the extra mile to guard against intruders. Available in capacities up to 5 TB, the CANVIO Desktop is the ideal partner for your TV or PC.
  • Interface USB 3.0 (USB 2.0 compatible)
  • Max. transfer rate ~ 5.0 Gbs
  • Color Black
  • Capacity 5TB
  • Rotational speed 7200 rpm
  • Cache buffer 32 MB
  • Average seek time 14 ms
  • File system NTFS (MS Windows) *The drive can be re-formatted to HFS+ file system for full Mac compatibility.
  • Power AC Power adapter cable / Input: 100-240V, 650mA / Output: 12V - 2A / exchangeable plug head
  • Dimensions 129 (L) x 42 (W) x 167 (H) mm
  • Backup software NTI Backup Now EZ
  • System requirements Windows® XP / VISTA® / Windows® 7 - CPU with 750 MHz or faster, 10MB system hard disk space, 256MB system memory, one free port of USB 3.0 or USB 2.0
  • Box content STOR.E CANVIO, NTI Backup Now EZ software (pre-loaded), USB 3.0 cable ("A" to Micro "B" 2.5"), AC adapter cable, Quick Start Guide, User's Manual (pre-installed on the hard drive), Warranty Leaflet
  • 2 year warranty
These hard drives are easy to carry and nice to look at. You get a choice of colours and versatile mounting options. Available in several capacity sizes, STOR.E CANVIO desktop hard drives are perfect for storing data, music, pictures, and more.
These hard drives come with pre-loaded backup software that provides file, folder, and full system backup and recovery. Password encryption keeps unauthorised users from accessing your valuable data.
Product Description Toshiba StorE Canvio - hard drive - 5 TB - USB 3.0
Type Hard drive - external (desktop) - password authentication, NTFS formatted
Capacity 5 TB
Form Factor 3.5"
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Buffer Size 32 MB
Spindle Speed 7200 rpm
Features Password authentication, NTFS formatted
Power Source Included AC adapter
Enclosure Colour Matte black
Dimensions (WxDxH) 4.2 cm x 12.9 cm x 16.7 cm
Localisation United Kingdom
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba 5TB Canvio USB...
