Toshiba 8TB N300 High-Reliability NAS Hard Drive - SATA 6Gb/s...
FREE DELIVERY
Toshiba 8TB N300 High-Reliability NAS Hard Drive - SATA 6Gb/s 7200RPM 128MB Cache
£209.28
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Supports multi-RAID systems with up to 8 bays
  • Designed for 24/7 operation with workloads up to 180TB/year
  • Integrated RV sensors help ensure high reliability against shock and vibrations by detecting and minimizing rotational vibration effects in multi-bay NAS system
  • On-board cache algorithm and buffer management optimize cache allocation between read and write cycles for improved real-time drive performance
  • Fast data transfer speed provides quick access to essential content
  • Ramp loading technology reduces wear to the recording head and media for improved drive reliability
  • Error Recovery Control technology minimizes critical downtime for multi-RAID environment by optimizing data error recovery time
  • Secured motor shaft at both ends helps reduce system-induced vibrations, stabilizing the platters for improved tracking accuracy and performance during read and write operations
  • Adjust seek speed automatically to reduce heat buildup during high temperature operation
  • Form Factor: 3.5"
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 8TB
  • Spin Speed (rpm): 7200rpm
Product codes
Toshiba’s N300 3.5-inch internal hard disk offers unprecedented reliability for NAS and other high-performance storage systems. It is optimized to meet the reliability, endurance, performance and scalability requirements of 24-hour x 7-day high-capacity storage for personal, home office and small business use. The N300 is available in capacities of up to 8 TB.
Use for:
• Up to 8-bay NAS
• Desktop RAID and servers
• Multimedia server storage
Optimised for use in 1-8 bay NAS enclosures
3.5" SATA hard drive
7200 rpm / 128 MB buffer
Product Description Toshiba N300 NAS - hard drive - 8 TB - SATA 6Gb/s
Type Hard drive - internal - shock sensor, NAS compatible, 24x7 continuous operation, vibration sensor, workload up to 180 TB per year
Capacity 8 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 128 MB
Spindle Speed 7200 rpm
Features Shock sensor, NAS compatible, 24x7 continuous operation, vibration sensor, workload up to 180 TB per year
Dimensions (WxDxH) 101.85 mm x 147 mm x 26.1 mm
Weight 770 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba 8TB N300 High-...
£209.28
