Toshiba Battery Li-Ion 6 Cell 5100mAh
Product codes
The Toshiba Primary Battery Pack is a rechargeable, Lithium Ion battery. Used as either a spare or replacement battery, this battery pack meets or exceeds the specifications of the original battery that came with your notebook. It interfaces with the Toshiba Power Saver Utility on the notebook which features a charge indicator to help you monitor the available power.
Product Description Toshiba Primary Battery Pack - laptop battery - Li-Ion - 5100 mAh
Device Type Laptop battery
Weight 327 g
Battery Lithium Ion 6-cell - 5100 mAh
Batteries Qty 1
Run Time (Up To) 4.6 hours
Dimensions (WxDxH) 20.6 cm x 4.5 cm x 2 cm
Manufacturer Warranty 1 year warranty
Designed For Satellite Pro S500; Tecra A11, A11 3G-13, M11, S11
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Toshiba Battery Li-Ion...
