Toshiba C50-A-1HP 15.6" Core i3 3120M 2.5GHz 6GB 500GB...
Toshiba C50-A-1HP 15.6" Core i3 3120M 2.5GHz  6GB 500GB DVD HDMI USB3  W8
Key features
  • With Intel processor, you can create the ideal business laptop for your everyday needs
  • Higher speeds and an efficient performance
  • Bluetooth 4.0 built in
  • Delivers a consistently powerful performance, from boot-up to shut-down
  • 39.6 cm (15.6") HD LED backlight display
Product codes
The Toshiba 15.6" C50 Core i3 Laptop
When you consider a laptop purchase it worth while to consider how well built tha laptop is and Toshiba have always been known for high quality. This build ethic is also backed up in this laptop with a seriously powerful Intel Core i3 3120m 2.5GHz processor and 6GB ram. When you add this to the massive amount of ways to connect including: Bluetooth, HDMI and USB3 then you really have a best in class machine in the mid/high range category.
Well Connected
Toshiba laptops come with a range of features and connectivity options that enhance your user experience. The spacious full size keyboard with numeric keypad is ideal for applications such as spreadsheets, and ensures typing is comfortable. Swap pictures and files or expand your storage capabilities using the SD card slot, plug into the 1x USB 3.0 or 2x USB 2.0 ports to share content with your other devices. USB 3.0 is the latest USB standard that offers transfer rates up to 10 times faster than Hi-Speed USB 2.0. HDMI connectivity enables high definition connectivity from your laptop to AV equipment including your HD TV.
Streamlined Design
The Satellite C50 features a new streamlined design with a textured matt black finish and weighs from only 2.4kg. The textured finish helps to minimise fingerprint marks as well as giving a smart look and feel. The 39.6cm (15.6") display with LED backlighting delivers sharp and vivid images.
High Quality Audio
The integrated stereo speakers are positioned below the screen and combine with DTS Sound audio suite to ensure that music or movie soundtracks can be enjoyed at their best. DTS Sound includes a sound enrichment suite that boosts volume, enhances bass and improves definition. Enjoy immersive audio complete with deep, rich bass and crystal clear dialogue. DTS Sound also delivers high-frequency definition for crisp detail in any listening environment, ensuring users a premium and natural entertainment experience whether you are using the laptop speakers or headphones.
MAIN FEATURES
  • Processor: Intel Core i3 3120M (2.5GHz, 2MB Cache)
  • Screen: 15.6" (Toshiba TruBrite TFT, 1366x768 WXGA resolution, LED Backlight)
  • RAM 6GB: (DDR3)
  • Hard Drive: 500GB
  • Optical Drive: DVD Rewriter (Records DVDs 8x & CDs 24x & Dual Layer Super Multi)
  • Graphics: Integrated (Intel HD Graphics)
  • Wireless LAN: Wireless (802.11b/g/n Wireless)
  • Network Card: 10/100/1000 Gigabit Fast Ethernet
  • Features: WEBCAM , CARD READER (SD/SDHC,MMC) , BLUETOOTH 4.0
  • Ports : 2x USB 2.0, 1x USB 3.0 , HDMI, VGA
  • Speakers: Integrated Sound System
  • OS: Win8
  • Warranty: 12 Months
Product Description Dynabook Toshiba Satellite Pro C50-A-1HP - 15.6" - Core i3 3120M - 6 GB RAM - 500 GB HDD
Product Type Notebook
Operating System Win 8.1 64-bit
Processor Intel Core i3 (3rd Gen) 3120M / 2.5 GHz / 3 MB Cache
Memory 6 GB DDR3 (1 x 4 GB + 1 x 2 GB)
Storage 500 GB HDD / 5400 rpm
Optical Drive DVD SuperMulti
Display 15.6" LED backlight 1366 x 768 / HD
Graphics Intel HD Graphics 4000
Numeric Keypad Yes
Integrated Webcam Yes
Networking 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
Battery Up to 3.5 hours
Colour Matt black with hairline pattern, black keyboard
Dimensions (WxDxH) 38 cm x 24.2 cm x 3.335 cm
Weight 2.3 kg
Localisation Region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty EMEA warranty - 1 year - carry-in
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
