Toshiba Canvio for Smartphone 500GB Mobile 2-in-1 Backup and...
Toshiba Canvio for Smartphone 500GB Mobile 2-in-1 Backup and Charging Solution
Key features
  • Compact and anti-slip design for easy portability
  • USB-powered for easy plug-and-play operation
  • Internal shock sensor and ramp loading technology help protect your drive and data
Product codes
BACKUP. CHARGE. RELAX.
Stay cool. The Toshiba Canvio for Smartphone backs up your data and charges your smartphone in one single user operation, so you can focus on the important things in your life. All you need is the sleek Canvio for Smartphone and Android app - connect up and you get a backup each time you charge, automatically. There's no need to worry about the technical details. Your photos, videos, music, contacts and documents are kept current and safe. And if you lose your phone or upgrade to a new model, you just transfer the data to the new device and you're good to go.
EASY 2-IN-1 OPERATION
It's as easy as charging your phone. Just connect your phone to charge and backup takes care of itself automatically after activating the function in the easy-to-use Android app. You don't have to worry about saving important personal data any more. Canvio for Smartphone does it for you.
To work with the Canvio for Smartphone your phone needs to support USB On-The-Go (USB OTG) function.
PEACE OF MIND
A lot can happen to a smartphone: they get dropped, soaked and stolen. You'll never again have to worry about losing your contact list, documents or that special video or photo. All you need is the Android app and the Canvio for Smartphone and your valuable data is regularly backed up and secure.
NEW PHONE, NO PROBLEM
You'll be up and running quickly when you upgrade to a new phone. The Canvio for Smartphone provides an easy route which simplifies the set-up of new smartphones. It transfers your photos, videos, music, contacts and documents simply and seamlessly from your old to your new device with just a few clicks.
LOOKING GOOD
The elegant Canvio for Smartphone is a stylish addition to any room and includes a massive 500 GB capacity, giving you ample space to back up your photos, videos, music, contacts and documents. You could store up to 120,000 music tracks or 220,000 images.
ONE FOR ALL
Whether you charge in the living room or on your bedside table, your data is kept safely at home, avoiding the risks and costs of a cloud solution. And, because the Canvio for Smartphone can be shared by several devices, the whole family can benefit - everyone can share their data and keep it safe and secure.
MORE THAN BACKUP
The Canvio for Smartphone is also great for data management. Even without a PC, files can be copied and deleted via the smartphone app. Additionally, you can use it as a regular hard disk with your PC and play the stored files on your Smartphone. It supports MicroUSB, Type-A and Type-C USB which gives you more flexibility to connect to existing and future devices.
Toshiba Canvio for Smartphone - hard drive - 500 GB - USB 2.0
Hard drive - external (desktop)
500 GB
USB 2.0
Automatic backup, NTFS formatted
Power Source
Included AC adapter
145 mm x 145 mm x 15 mm
210 g
United Kingdom, Europe
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba Canvio for Sma...
