Toshiba Enterprise HDD 10TB 3.5’’ SATA 6Gbit/s 7200RPM
£263.67
Delivery:
Standard: 1-3 working days
Key features
  • Industry standard 3.5-inch 26.1 mm height form
  • Large capacity
  • 7,200 rpm performance
  • SATA 6.0 Gbit/s interface
  • MTTF 2.5 M hours
  • Toshiba Persistent Write Cache technology for data-loss protection in sudden power-loss events
  • Form Factor: 3.5
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 10TB
  • Spin Speed (rpm): 7200rpm
Product codes
The MG06ACA Enterprise Capacity HDD models provides up to 10TB of capacity and 7,200 rpm performance, in a robust design engineered for nearline business-critical workloads.
The MG06ACA model generation utilizes industry-standard 3.5-inch 26.1 mm height form factor and Advanced Format sector technologies for optimum capacity and data reliability. Models support Toshiba Persistent Write Cache technology which helps enhance performance while assuring the consistency of write operations in the event of a sudden loss of power. Equipped with SATA 6.0 Gbit/s interface, the Enterprise Capacity MG06ACA models help to save rack space and reduce the footprint and operational burden of business critical servers and storage systems.
The MG06ACA Series improves sustained transfer rate performance to 237 MiB/s and increases MTTF by 25% when compared to the prior MG05ACA series. 4Kn or 512e Advanced Format Sector Technology models are available. 4Kn sector models (MG06ACAxxxA) offer suitable performance and compatibility with the 4Kn-capable applications and operating environments. 512e sector models (MG06ACAxxxE) provide support for legacy applications and operating environments that require 512 byte sector lengths.
  • Industry Standard 3.5-inch 26.1 mm Height Form.
  • Large 10TB Capacity; plus 8TB and 6TB MG06 Series models.
  • 7,200 rpm Performance.
  • SATA 6.0 Gbit/s Interface.
  • MTTF 2.5 M hours.
  • 550 Total TB Transferred per Year Workload Rating.
  • 4Kn or 512e Advanced Format Sector Technology.
  • Toshiba Persistent Write Cache Technology for Data-Loss Protection in Sudden Power-Loss Events.
  • Improved sustained transfer rate.
  • Sanitize Instant Erase (SIE) option model available.
Product Description Toshiba Enterprise Capacity MG06ACAxxxx Series MG06ACA10TE - hard drive - 10 TB - SATA 6Gb/s
Type Hard drive - internal
Capacity 10 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features Advanced format 512e, Persistent Write Cache technology, Power Loss Protection (PLP)
Dimensions (WxDxH) 26.1 mm
Weight 770 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£263.67
