Toshiba Enterprise HDD 12TB 3.5’’ SATA 6Gbit/s 7200RPM
£278.00
More than 50 In Stock
Delivery:
Standard: 1-3 working days
  • Form Factor: 3.5
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 12TB
  • Spin Speed (rpm): 7200rpm
Product codes
The MG07ACA Enterprise Capacity SATA HDD provides great conventional magnetic recording (CMR) capacity and 7,200 rpm performance. The industry-standard 3.5-inch form-factor integrates easily into cloud-scale storage infrastructure, business-critical servers and storage, and File and Object storage solutions.
The MG07ACA Series utilizes Toshiba precision laser welding technology to seal helium inside the 9-disk mechanics for the life of the drive. The helium-sealed design reduces aerodynamic drag to deliver a lower operational power profile, helping to achieve TCO objectives for cloud-scale and software-defined data center infrastructure.
Product Description Toshiba Enterprise Capacity MG07ACAxxx Series MG07ACA12TE - hard drive - 12 TB - SATA 6Gb/s
Type Hard drive - internal - nearline
Capacity 12 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features 24x7 availability, Persistent Write Cache technology, Power Loss Protection (PLP), Conventional magnetic recording (CMR), Helium Sealed-Drive Design, 512 emulation ( 512e )
Dimensions (WxDxH) 101.85 mm x 147 mm x 26.1 mm
Weight 720 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£278.00
