Toshiba Enterprise HDD 8TB 3.5’’ SATA 6Gbit/s 7200RPM
£236.97
Delivery:
Standard: 1-3 working days
Key features
  • Large capacity
  • Excellent performance
  • SATA 6.0 Gbit/s interface
  • Advanced Format Sector technology
  • Toshiba Persistent Write Cache technology
  • Improved sustained transfer rate
  • Form Factor: 3.5"
  • Type: Hard drive
  • Interface Type: Serial Attached SCSI
  • Capacity: 8TB
  • Spin Speed (rpm): 7200rpm
Product codes
The MG05ACA Enterprise Capacity HDD provides excellent capacity and great performance, in a robust design engineered for near line business-critical workloads. The MG05ACA utilizes industry-standard 3.5-inch form factor and Advanced Format sector technologies for optimum capacity and data reliability. This models support Toshiba Persistent Write Cache technology which helps enhance performance with handling data in the event of a sudden loss of power. Equipped with SATA 6.0 Gbit/s interface, the Enterprise Capacity MG05ACA models help save rack space and reduce the footprint and operational burden of business critical servers and storage systems.
Product Description Toshiba MG05ACA series MG05ACA800E - hard drive - 8 TB - SATA 6Gb/s
Type Hard drive - internal - nearline - Halogen Free, business critical, 24x7 continuous operation, advanced format 512e, antimony free, Persistent Write Cache technology
Capacity 8 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 128 MB
Spindle Speed 7200 rpm
Features Halogen Free, business critical, 24x7 continuous operation, advanced format 512e, antimony free, Persistent Write Cache technology
Dimensions (WxDxH) 101.85 mm x 147 mm x 26.1 mm
Weight 770 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba Enterprise HDD...
£236.97
