Toshiba Hi-speed Port Replicator III 180W - UK Version
Key features
  • Includes 2 x USB 3.0 ports for high data transfer rate and greater functionality
  • Easy one-touch connection to your desktop environment eliminates the need to reconnect cables
  • Supports warm docking/undocking and wake-on LAN and wake up USB
  • Accommodates extended capacity battery, no need to remove it when you dock
  • System switch with one-touch disconnect button
Product codes
With the ability to attach up to six USB devices simultaneously, together with HDMI, Display and GigaLAN Fast Ethernet ports, Toshiba's Hi Speed Port Replicator III delivers comprehensive connectivity and lightning-fast performance to your laptop - with no cables in sight. Simply plug in your machine and enjoy immediate access to all your peripherals, from printers, storage and screens to keyboards, mice and power sources. It's the perfect way to stay productive while keeping your workspace the way you want it.
Product Description Toshiba Hi Speed Port Replicator III - port replicator - VGA, DVI, HDMI, DP
Product Type Port replicator
Video Interfaces VGA, DVI, HDMI, DP
Dimensions (WxDxH) 38.09 cm x 14.9 cm x 3.15 cm
Weight 720 g
Colour Black
Localisation United Kingdom
Power Power adapter - external 180 Watt
Designed For Dynabook Toshiba Portégé R30, Z30; Toshiba Tecra A50, W50, Z40, Z50
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Toshiba Hi-speed Port...
