Toshiba High Speed Port Replicator III - 120W Standard
Key features
  • Includes 2 x USB 3.0 ports for high data transfer rate and greater functionality
  • Easy one-touch connection to your desktop environment eliminates the need to reconnect cables
  • Supports warm docking/undocking and wake-on LAN and wake up USB
  • Accommodates extended capacity battery, no need to remove it when you dock
  • System switch with one-touch disconnect button
Product codes
With the ability to attach up to six USB devices simultaneously, together with HDMI, Display and GigaLAN Fast Ethernet ports, Toshiba's Hi Speed Port Replicator III delivers comprehensive connectivity and lightning-fast performance to your laptop - with no cables in sight. Simply plug in your machine and enjoy immediate access to all your peripherals, from printers, storage and screens to keyboards, mice and power sources. It's the perfect way to stay productive while keeping your workspace the way you want it.
Toshiba Hi Speed Port Replicator III - port replicator - VGA, DVI, HDMI, DP
Port replicator
Video Interfaces
VGA, DVI, HDMI, DP
38.09 cm x 14.9 cm x 3.15 cm
720 g
United Kingdom
Power adapter 120 Watt
1 year warranty
Portégé A30-C, R30-A, Z30-A, Z30-B, Z30-C; Tecra A40-C, A50-A, A50-C, Z40-A, Z40-B, Z40-C, Z50-A, Z50-C
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Toshiba High Speed Por...
