Toshiba Main Battery Pack 10.8v 9200mAh
£68.70
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Laptop Battery
  • Function battery performs: Laptop, Main power battery for portable computers
  • Battery Chemistry: Lithium ion, Newer type of rechargable, giving best performance for a rechargable
Product codes
Toshiba batteries are of the same quality, reliability, and specification as the original primary pack included with your Notebook. Whether replacing an old battery, or simply wishing to carry a spare, the Toshiba range will enable you to be more productive and provide you with the power you need, when you need
2-Power Main Battery Pack - laptop battery - Li-Ion - 9200 mAh
Laptop battery
0.58 kg
Lithium Ion 12-cell - 9200 mAh
Battery Form Factor
Internal
Batteries Qty
1
23.4 cm x 5 cm x 4.1 cm
1 year warranty
Toshiba Satellite A660, A660/07, A665, L630, L630/00, L630/037, L630/063, L645, L650, L655, L670, L675, L750, L750/03, L750/04, L750/052, L755, L775, P750/02, P750/05, P755, T110, T130, T130/01, T130/03; Satellite Pro L650/00, L650/02, L650/042, L670/01, L670/02, L670/029, T110/00, T110/009, T130/00
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba Main Battery P...
£68.70
