Toshiba Main Battery Pack 10.8v 9200mAh
£68.70
Delivery:
Standard: 1-3 working days
Key features
  • Laptop Battery
  • Function battery performs: Laptop, Main power battery for portable computers
  • Battery Chemistry: Lithium ion, Newer type of rechargable, giving best performance for a rechargable
  • Device Screen Size: [N/A]
  • Stock Status: In Stock
Product codes
Toshiba batteries are of the same quality, reliability, and specification as the original primary pack included with your Notebook. Whether replacing an old battery, or simply wishing to carry a spare, the Toshiba range will enable you to be more productive and provide you with the power you need, when you need
Product Description 2-Power Main Battery Pack - laptop battery - Li-Ion - 9200 mAh
Device Type Laptop battery
Weight 0.58 kg
Battery Lithium Ion 12-cell - 9200 mAh
Battery Form Factor Internal
Batteries Qty 1
Dimensions (WxDxH) 23.4 cm x 5 cm x 4.1 cm
Manufacturer Warranty 1-year warranty
Designed For Dynabook Toshiba Satellite Pro L650/00, L650/02, L650/042, L670/01, L670/02, L670/029, T110/00, T110/009, T130/00; Toshiba Satellite A660, A660/07, A665, L630, L630/00, L630/037, L630/063, L645, L650, L670, L675, L750/03, L750/052, L755, L775, P750/02, P750/05, P755, T110, T130, T130/01, T130/03
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba Main Battery P...
£68.70
