Toshiba P300 2TB 3.5" SATA 6Gb/s 7200rpm 64MB High Perfo...
Toshiba P300 2TB 3.5" SATA 6Gb/s 7200rpm 64MB High Performance Drive
£52.82
40 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High performance designed for everyday computing
  • Data Protection technology
  • Drive reliability
  • Native Command Queuing (NCQ) support
  • Broad compatibility
  • Form Factor: 3.5"
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 2TB
  • Spin Speed (rpm): 7200rpm
Product codes
Toshiba’s P300 3.5" internal hard drive delivers a high performance for professionals. With its dual-stage actuator, you can count on smooth, responsive computing. What's more, your data and media is secured with a ramp loading design that prevents damage on the move, as well as a shock sensor. The P300 is available in capacities up to 3 TB.
Product Description Toshiba P300 Desktop PC - hard drive - 2 TB - SATA 6Gb/s
Type Hard drive - internal - Native Command Queuing (NCQ), Advanced Format technology, Data Protection Technology
Capacity 2 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 64 MB
Spindle Speed 7200 rpm
Features Native Command Queuing (NCQ), Advanced Format technology, Data Protection Technology
Dimensions (WxDxH) 101.85 mm x 147 mm x 26.1 mm
Weight 680 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba P300 2TB 3.5"...
£52.82
