Toshiba Portege X20W-D-10Q 12.5" C i5-7200 8GB 256GBSSD
£1,236.42
Delivery:
Standard: 1-3 working days
Key features
  • Elegant design
  • Unshakeable mobile security
  • An all-day business partner
  • Capture your ideas without compromise
Product codes
This is a thin and light professional 2-in-1 laptop. However, with a powerful processor inside, the Hybrid Air cooling system, keeping things running smoothly and a fully magnesium chassis, it represents engineering excellence. Featuring a SecurePad with fingerprint reader and IR-camera for face authentication, the laptop is equipped for professional-standard security to protect your business-critical data. This 2-in-1 is robust and ready for secure working anywhere.
The laptop is built for comfortable daily working - with a long battery life and step charge technology, that delivers additional hours. Add a non-reflective Corning Gorilla Glass 4 screen, connectivity, including Thunderbolt 3, and beautifully crisp Harmon/Kardon audio output, and there's nothing holding you back from being productive, wherever work takes you. With a Palm Rejection technology and a keyboard, that's not only backlit but also pitched perfectly for added comfort, the laptop is designed for enhanced usability - so you can capture your ideas with ease. What's more, whether you're at work, home, or on the move, the laptop is easily managed alongside the rest of your IT fleet and infrastructure.
Product Description Dynabook Toshiba Portégé X20W-D-10Q - 12.5" - Core i5 7200U - 8 GB RAM - 256 GB SSD
Product Type Notebook - flip design
Operating System Win 10 Pro 64-bit
Processor Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
Memory 8 GB LPDDR3
Storage 256 GB SSD
Optical Drive No optical drive
Display 12.5" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics Intel HD Graphics 620
Input Device DualPoint, digital pen
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2
Battery 3-cell - up to 14.75 hours
Security Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Colour Onyx blue with hairline
Dimensions (WxDxH) 29.9 cm x 21.9 cm x 1.54 cm
Weight 1.1 kg
Localisation Region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty EMEA warranty - 1 year - carry-in
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba Portege X20W-D...
£1,236.42
