This is a thin and light professional 2-in-1 laptop. However, with a powerful processor inside, the Hybrid Air cooling system, keeping things running smoothly and a fully magnesium chassis, it represents engineering excellence. Featuring a SecurePad with fingerprint reader and IR-camera for face authentication, the laptop is equipped for professional-standard security to protect your business-critical data. This 2-in-1 is robust and ready for secure working anywhere.
The laptop is built for comfortable daily working - with a long battery life and step charge technology, that delivers additional hours. Add a non-reflective Corning Gorilla Glass 4 screen, connectivity, including Thunderbolt 3, and beautifully crisp Harmon/Kardon audio output, and there's nothing holding you back from being productive, wherever work takes you. With a Palm Rejection technology and a keyboard, that's not only backlit but also pitched perfectly for added comfort, the laptop is designed for enhanced usability - so you can capture your ideas with ease. What's more, whether you're at work, home, or on the move, the laptop is easily managed alongside the rest of your IT fleet and infrastructure.
Product Description | Dynabook Toshiba Portégé X20W-D-10Q - 12.5" - Core i5 7200U - 8 GB RAM - 256 GB SSD | Product Type | Notebook - flip design | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache | Memory | 8 GB LPDDR3 | Storage | 256 GB SSD | Optical Drive | No optical drive | Display | 12.5" LED backlight touchscreen 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Input Device | DualPoint, digital pen | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 | Battery | 3-cell - up to 14.75 hours | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Colour | Onyx blue with hairline | Dimensions (WxDxH) | 29.9 cm x 21.9 cm x 1.54 cm | Weight | 1.1 kg | Localisation | Region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | EMEA warranty - 1 year - carry-in |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB |
Max RAM Supported | 8 GB |
Technology | LPDDR3 SDRAM |
Speed | 1600 MHz |
Storage | |
Main Storage | 256 GB SSD |
Display | |
Type | 12.5" |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | Anti-reflective, Corning Gorilla glass 4 |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes |
Camera Features | Face recognition, Windows Hello, IR LED |
Sound | Harman/kardon stereo speakers |
Compliant Standards | DTS Studio Sound |
Input | |
Type | Keyboard, DualPoint, digital pen |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 |
Compliant Standards | Wi-Fi CERTIFIED |
Battery | |
Technology | 3-cell lithium polymer |
Run Time | Up to 14.75 hours |
AC Adapter | |
Input | AC 100 - 240 V (50 - 60 Hz) |
Output | 20 V, 2.25 A |
Connections & Expansion | |
Interfaces | USB-C 3.1 Gen 2/Thunderbolt 3 , USB 3.0 (Sleep & Charge) , Headphone/microphone combo jack , HDMI (on supplied adapter) |
Software | |
Software Included | Toshiba Eco Utility, Microsoft Office 365 (30 days trial) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Cables Included | USB-C to HDMI adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 1.1 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | EMEA warranty - 1 year - carry-in |
