Toshiba Q300 Pro 256GB 2.5" 7mm SATA 6GB/s SSD
Key features
  • Advanced speed technology - Adaptive Size SLC Write cache technology
  • Native Command Queuing (NCQ)
  • Ready only mode
  • Patrol read
  • Thermal control
Product codes
Boost your computer's boot-up and operation performance with Toshiba's 19 nm Solid State Drive technology. With a blazing fast SATA III interface, your computer's performance will make a quantum leap forward. The 7 mm slim SSD includes a spacer you will need for a firm fit in a 9.5 mm hard disk slot and also a cloning software you will need for exchanging your hard drive with the SSD.
Q300 Pro, the Toshiba SSD flagship model strikes a balance between the conflicting demands for impressive high-speed processing and lower power consumption at a stellar dimension of excellence.
Awesome Low PowerConsumption
Leading-class Sequential Read/Write Performance
Among best-in class Random Read/Write Performance
256GB
Sequential Read (Max) 550MB/s
Sequential Write (Max) 520MB/s
Random Read (Max) 92,000 IOPS
Random Write (Max) 63,000 IOPS
Performance data is based on Toshiba internal test results. The read and write speed may vary depending on the conditions.
Product Description Toshiba Q300 Pro - solid state drive - 256 GB - SATA 6Gb/s
Type Solid state drive - internal - Native Command Queuing (NCQ), TRIM support, Garbage Collection technology, Zero Trim Support, Adaptive Size SLC Write cache technology
Capacity 256 GB
NAND Flash Memory Type Multi-level cell (MLC)
Form Factor 2.5"
Interface SATA 6Gb/s
Features Native Command Queuing (NCQ), TRIM support, Garbage Collection technology, Zero Trim Support, Adaptive Size SLC Write cache technology
Dimensions (WxDxH) 69.85 mm x 100 mm x 7 mm
Weight 53 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba Q300 Pro 256GB...
