Give your business an edge with this enterprise-class laptop built for small or medium-sized businesses. The slim, smart and feature-rich Satellite Pro R50 will meet all your computing needs without putting a big dent in your bottom line. Powered by the powerful processor, you will be able to effectively manage your workload wherever the day takes you.
Product Description | Dynabook Toshiba Satellite Pro R50-C-17C - 15.6" - Core i5 6200U - 4 GB RAM - 128 GB SSD | Product Type | Notebook | Operating System | Windows 10 Home | Processor | Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz) / 3 MB Cache | Memory | 4 GB DDR3L (1 x 4 GB) | Storage | 128 GB SSD | Optical Drive | DVD SuperMulti | Display | 15.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 520 | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Battery | 4-cell - up to 8 hours | Features | 3D sensor | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Graphite black | Dimensions (WxDxH) | 37.9 cm x 25.8 cm x 2.395 cm | Weight | 2.1 kg | Localisation | Region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | EMEA warranty - 1 year - pick-up and return |
General | |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz / PC3-12800 |
Rated Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 128 GB SSD |
Optical Drive | DVD±RW (±R DL) / DVD-RAM |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | HighBrightness, anti-reflective |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes - HD |
Sound | Stereo speakers, microphone |
Compliant Standards | DTS Sound |
Input | |
Type | Keyboard, touchpad |
Features | Multi-gesture touch pad, Palm Rejection Technology |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 |
Network Interface | Gigabit Ethernet |
Features | Intel Wireless Display (WiDi) |
Compliant Standards | Wi-Fi CERTIFIED |
Battery | |
Technology | 4-cell Lithium Ion |
Run Time | Up to 8 hours |
AC Adapter | |
Input | AC 120/230 V |
Output | 19 V, 2.37 A |
Connections & Expansion | |
Interfaces | LAN , VGA , HDMI |
Software | |
Software Included | Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft Office 365 (30 days trial), DTS Sound, McAfee LiveSafe (30 days subscription) |
Miscellaneous | |
Integrated Options | 3D sensor |
Features | Administrator password, system password, hard drive password |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 2.1 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | EMEA warranty - 1 year - pick-up and return |
