Toshiba Satellite Pro R50-C-15W 15.6 INCH - Ci3-6006U 4GB 500...
Toshiba Satellite Pro R50-C-15W 15.6 INCH - Ci3-6006U 4GB 500GB DVDR
£557.29
28 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Long term value
  • The standalone solution
Product codes
PROFESSIONAL PERFORMANCE
The Satellite Pro R50-C has been designed specifically to meet the requirements of professionals. The device offers a solid combination of performance and reliability – backed up by Toshiba’s history of over 30 years of notebook development. Designed to be a reliable companion in the business environment, the Satellite Pro R50-C has a keyboard that can withstand heavy daily use, a 3D sensor for data protection, and is drop tested to ensure its ruggedness.
LONG TERM VALUE
The Satellite Pro R50-C is a cost effective device that professionals can rely on. That’s because the device has been built to last – making it great value for money in the long run. You can feel reassured by a solid design that’s built to withstand the pressures of daily use – with a selection of the latest features that won’t date quickly.
THE STANDALONE SOLUTION
Built to work straight out of the box, the Satellite Pro R50-C reaches maximum performance without relying on external peripherals. With Intel® Core™ architecture, Wi-Fi and LAN capabilities, the device single-handedly delivers on every professional demand. The Satellite Pro R50-C has a 38.1cm (15") matt screen that combats the glare of office lighting, an advanced system that supports silent working and a full size keyboard for added convenience and comfort.
PREMIUM WITHOUT THE PRICETAG
With premium components housed in a highly resistant body, the Satellite Pro R50-C is built to handle the challenges of even the most demanding professional environments. The device is secure, too: A Kensington lock slot offers security for the device itself. And McAfee security software is pre-installed to protect all your data from the moment the laptop is turned on.
CONNECTED TO YOUR BUSINESS NEEDS
The Satellite Pro R50-C is well connected, enabling you to save, store and share data however suits you best. With HDMI, RGB, USB 3.0 and LAN, connecting to peripherals in or out of the office is easy. Plus, there’s an SD card slot enabling you to rapidly export data away from the machine when required.
PERSONALISE YOUR PROFESSION
The Satellite Pro R50-C supports a wide range of accessories designed for business users. You can quickly connect additional displays and desktop peripherals with the Dynadock range, extend hard drive space with Toshiba’s external devices, and transport and store the device safely with official bags, sleeves, trolleys and more.
CERTIFIED ECO-FRIENDLY
Take control of your environmental impact with Toshiba’s EPEAT Gold certified Satellite Pro R50-C with Eco Utility built-in. You can quickly and easily customise your computer settings to maximise power efficiency, minimise energy consumption, and reduce the impact your work has on the planet.
Services for a flawless performance
The impeccable operation of your Toshiba product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Product Description Dynabook Toshiba Satellite Pro R50-C-15W - 15.6" - Core i3 6006U - 4 GB RAM - 500 GB HDD
Product Type Notebook
Operating System Win 10 Pro 64-bit
Processor Intel Core i3 (6th Gen) 6006U / 2 GHz / 3 MB Cache
Memory 4 GB DDR3L (1 x 4 GB)
Storage 500 GB HDD / 5400 rpm
Optical Drive DVD SuperMulti
Display 15.6" LED backlight 1366 x 768 / HD
Graphics Intel HD Graphics 520
Numeric Keypad Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
Battery 4-cell - up to 8 hours
Features 3-axis accelerometer
Security Trusted Platform Module (TPM 2.0) Security Chip
Colour Graphite black, black (keyboard)
Dimensions (WxDxH) 37.9 cm x 25.8 cm x 2.395 cm
Weight 2.1 kg
Localisation Region: United Kingdom
Pricing Type BTO
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty EMEA warranty - 1 year - carry-in
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba Satellite Pro...
£557.29
