Toshiba Tecra Z40 Ultrabook -C12Z 14" i5 8GB 256GB Windo...
Toshiba Tecra Z40 Ultrabook -C12Z 14" i5 8GB 256GB Windows 10 Pro
£719.29
Delivery:
Key features
  • Windows 10 Pro 64-bit – Dynabook recommends Windows 10 Pro for business
  • 6th generation Intel Core i5-6200U processor with Intel Turbo Boost Technology 2.0
  • 35.6cm (14.0"), Full HD TFT non-reflective High Brightness and IPS Technology display with LED backlighting and 16:9 aspect ratio
  • Solid State Drive 256 GB
  • Steel grey metallic, magnesium chassis, matt black keyboard
  • 8,192 (1x) MB, DDR3L RAM (1,600 MHz)
  • Intel HD Graphics 520
  • Maximum life: up to 8h30min (Mobile Mark 2014 running Win10)
  • Weight: starting at 1.47 kg
  • W x D x H: 338.0 x 236.0 x 20.4 mm
  • Display Size: 14in
  • Processor Model: I5-6200U
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 8GB
  • Hard Drive Capacity: 256GB
Product codes
Made for mobile business
The Tecra Z40-C is ready to do business everywhere. Starting at an ultra-light 1.47 kg and highly robust, it's the perfect companion to take on your travels. Even without an extended battery, you get up to 12.5 hours* on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the 35.6 cm (14") non-reflective Full HD screen. So it's really convenient to type emails or create documents when you're working out of the office - even in dimly-lit conditions, using the illuminated keyboard.
Multi-tasking on the move
With the latest Intel® Core™ processor up to i7, as well as Intel® vPro™ technology, the Z40-C has all the power you need to multi-task on the move. And with high-performance SSDs and HDDs, the Tecra Z40-C offers plenty of storage, faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. There's no compromise, so you can run all of your business applications with ease.
Fully connected
The Tecra Z40-C is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster, using all three of the USB 3.0 ports. Or share your presentations in high-resolution brilliance, with HDMI. Gigabit LAN also allows fast access to your local network, while support for optional LTE gives you the freedom to work wirelessly, so you can be more productive anywhere. Connecting to your peripherals is fast and easy with the optional docking solution, which aligns with the other models in Toshiba's latest business line-up. The SD card slot boosts storage too.
Secure and easy to manage
The Tecra Z40-C is built for business, and comes loaded with tried-and-tested security and management features. There's the self-encrypted drives and Trusted Platform Module (TPM) to safeguard the critical data on your local storage. And even if your Z40-C needs to be updated, the IT department can do it at any time, with Intel Active Management Technology (AMT). The fingerprint and Smartcard reader makes it easy and secure to log on to your PC too, while the 3D sensor knows to take care of your data if your laptop falls.
Synergy across devices
The Tecra Z40-C shares many features with the latest business line-up from Toshiba, to ensure consistency across your company - no matter which models you choose. So you can easily access all of your peripherals using a wide range of ports, with the common docking station. The Z40-C also comes with dongle-free connectivity in the form of HDMI, RGB, Gigabit LAN and three USB 3.0 ports for added convenience and flexibility. All Toshiba laptops share the same software image, for easy customisation in one go. Plus, the fingerprint reader, non-reflective screen, webcam, magnesium chassis, Accupoint and docking connector all come as standard too.
Product Description Dynabook Toshiba Tecra Z40-C-12Z - 14" - Core i5 6200U - 8 GB RAM - 256 GB SSD
Product Type Notebook
Operating System Win 10 Pro 64-bit
Processor Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz) / 3 MB Cache
Memory 8 GB DDR3L (1 x 8 GB)
Storage 256 GB SSD
Optical Drive No optical drive
Display 14" LED backlight 1920 x 1080 / Full HD
Graphics Intel HD Graphics 520
Input Device DualPoint, ClickPad
Keyboard Backlight Yes
Integrated Webcam Yes
Networking Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
Battery 4-cell - up to 8.5 hours
Features Accelerometer
Dockable Yes
Security Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Colour Steel gray metallic, matte black keyboard
Dimensions (WxDxH) 33.8 cm x 23.6 cm x 2.04 cm
Weight 1.47 kg
Localisation Region: United Kingdom, Ireland
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty EMEA warranty - 1 year - carry-in
Bundled Services 1 Year Reliability Guarantee
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba Tecra Z40 Ultr...
£719.29
