Toshiba Z20t Rugged Case
£63.85
Delivery:
Key features
  • Double-layered protection: hard polycarbonate frame + soft impact silicone shell
  • Adjustable comfort nylon handle - rotates 360 degrees
  • Shoulder strap included
  • Access to all ports
  • Integrated pen loop
Product codes
The Portégé Z20t Rugged Case adds convenience and durability for the detachable Portégé Z20t display. A form fitted inner mold provides an additional layer of protection. The rubberized outer shell adds a shock-absorbing bumper. The built-in hand strap allows you to hold your tablet comfortably and securely, while allowing you to rotate the screen 360-degrees to the one perfect position.
Product Description Toshiba notebook carrying case
Product Type Notebook carrying case
Colour Black
Product Material Silicone, polycarbonate
Dimensions (WxDxH) 32 cm x 2.1 cm x 21.1 cm
Notebook Compatibility 12.5"
Features Removable shoulder strap, rugged, adjustable handle, shock absorption, pen loop, ports and controls access
Designed For Dynabook Toshiba Portégé z20, Z20T
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£63.85
