TP LINK 10/100M RJ45 to 100M Single-Mode SC Converter Full-Du...
TP LINK 10/100M RJ45 to 100M Single-Mode SC Converter Full-Duplex
£26.95
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Complies with 802.3u 10/100Base-TX, 100Base-FX standards
  • Link fault passthrough and far end fault minimize the loss caused by link failure timely
  • Provides switch configuration of half-duplex / full-duplex transfer mode for FX port
  • Extends fiber distance up to 20-60km
  • Auto negotiation of 10/100Mbps and auto MID/MID-X for TX port
  • Easy-to-view LED indicators provide status to monitor network activity easily
  • Type: Media Converter
  • Stock Status: In Stock
Product codes
The MC110CS is a media converter designed to convert 100BASE-FX fiber to 100Base-TX copper media or vice versa. Designed under IEEE 802.3u 10/100Base-TX and 100Base-FX standards, the MC110CS is designed for use with single-mode fiber cable utilizing the SC-Type connector. The MC110CS supports longwave (LX) laser specification at a full wire speed forwarding rate. It works at 1310nm on both transmitting and receiving data.
Other features of this module include the ability to be used as a stand alone device (no chassis required) or with TP-LINK's 19" system chassis, Auto MDI/MDI-X for TX port, auto negotiation of duplex mode on TX port, and front panel status LEDs. The MC110CS will transmit at extended fiber optic distances utilizing single-mode fiber up to 20 kilometers.
Product Description TP-Link MC110CS - fibre media converter - 10Mb LAN, 100Mb LAN
Device Type Fibre media converter - RJ-45 / SC single-mode
Form Factor External
Cabling Type 10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate 100 Mbps
Optical Wave Length 1310 nm
Data Link Protocol 10Mb LAN, 100Mb LAN
Max Transfer Distance 20 km
Dimensions (WxDxH) 9.5 cm x 7.3 cm x 2.7 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 10/100M RJ45 t...
£26.95
