Marketing description is not available.
Product Description | TP-Link TL-SG1210P - switch - 10 ports - unmanaged | Device Type | Switch - 10 ports - unmanaged | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 (PoE+) + 1 x 10/100/1000 (uplink) + 1 x Gigabit SFP (uplink) | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 63 W | Performance | Bandwidth: 20 Gbps | MAC Address Table Size | 4K entries | Features | Flow control, IGMP snooping, store and forward, fanless, metal housing, DSCP based QoS | Compliant Standards | IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at | Dimensions (WxDxH) | 20.9 cm x 12.6 cm x 2.6 cm |
General | |
Enclosure Type | Desktop |
PoE Budget | 63 W |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-T RJ-45 PoE+ , 1 x 1000Base-T RJ-45 uplink , 1 x Gigabit LAN SFP uplink |
Power | |
Power Device | External power adapter |
Power Provided | 53.5 V - 1.31 A |
Power Consumption Operational | 78.13 Watt |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Dimensions & Weight | |
Width | 20.9 cm |
Depth | 12.6 cm |
Height | 2.6 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
