TP-Link's TL-SM321B adopts the latest standard 1000Base-BX, transmission over a single strand of fiber, with one different wavelength going in each direction. You can extend the network distance up to 10Km with TP-Link's routers, switches, media converters to provide high speed and stability.
Product Description | TP-Link TL-SM321B - v2 - SFP (mini-GBIC) transceiver module - GigE | Device Type | SFP (mini-GBIC) transceiver module - LC/UPC single-mode | Form Factor | Plug-in module | Cabling Type | 1000Base-BX | Data Transfer Rate | 1.25 Gbps | Optical Wave Length | 1310 (TX) / 1550 (RX) nm | Data Link Protocol | GigE | Max Transfer Distance | 10 km | Designed For | JetStream TL-SG3452XP V1 |
General | |
Device Type | SFP (mini-GBIC) transceiver module |
Networking | |
Connectivity Technology | Wired |
Features | Bi-directional WDM transmission |
Compliant Standards | IEEE 802.3z |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-BX - LC/UPC single-mode female |
Miscellaneous | |
Compliant Standards | FCC |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 10 - 90% |
Compatibility Information | |
Designed For | TP-Link JetStream TL-SG3452XP V1 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
