TP LINK 16-port 10/100M Swit 16 RackMo
£34.63
Delivery:
Key features
  • Energy-efficient technology saves power up to 40%
  • 100% data filtering rate eliminates all error packets
  • Supports IEEE 802.3x flow control for full duplex mode and backpressure for half duplex mode
  • Non-blocking switching architecture forwards and filters packets at full wire-speed for maximum throughput
  • Auto-MDI/MDIX eliminates the need for crossover cables
  • Supports MAC address auto-learning and auto-aging
Product codes
The TL-SF1016 16-port 10/100Mbps Ethernet Switch is designed for SOHO (Small Office/Home Office) or workgroup users. The rack-mount size metal case design combined with a safety certified internal power supply make the Switch the most robust product which is very cost-effective for a less than 16 user environment. The plug-and-play and auto-negotiation capabilities allow the Switch to auto-detect its link partner (Ethernet adapter, for example) with the best speed. Each port provides full bandwidth (Maximum with 200Mbps in full duplex mode) without a traditional hub's collision phenomenon downgrading the performance. All ports can be the uplink (cascade) port, which is provided to link to another Switch for more ports expansion. Easy read LED indicators are supported for cable installation and normal operation diagnostics. The Switch can be used on desktop and rack-mount.
Product Description TP-Link TL-SF1016 - switch - 16 ports
Device Type Switch - 16 ports
Enclosure Type 1U
Subtype Fast Ethernet
Ports 16 x 10/100
Features Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3x
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 18 cm x 4.4 cm
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 16-port 10/100...
£34.63
