TP LINK 16-Port 10/100M Switch
£31.68
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Energy-efficient technology saves power up to 25%
  • Supports IEEE 802.3x flow control for full duplex mode and backpressure for half duplex mode
  • Non-blocking switching architecture that forwards and filters packets at full wire-speed for maximum throughput
  • 3.2 Gbps switching capacity
  • Store and forward switching scheme
  • Auto-MDI/MDIX eliminates the need for crossover cables
  • Supports MAC address auto-learning and auto-aging
  • Auto-negotiation ports provide smart integration between 10Mbps, 100Mbps hardware
  • Desktop and rack-mountable design
  • Plug and Play design simplifies installation
  • Fanless design to make sure it works quietly without disturbing your family
  • Type: Fast Ethernet
  • Ports: 16
  • Data Transfer Rate: 100Mbps
  • Managed: No
  • POE: No
Product codes
The TL-SF1016DS Fast Ethernet Switch provides you with a high-performance, low-cost, easy-to-use, seamless and standard upgrade to improve old network to 100Mbps network. All 16 ports support auto MDI/MDIX, no need to worry about the cable type, simply plug and play. Moreover, with the innovative energy-efficient technology, the TL-SF1016DS can save up to 25%* of the power consumption and 70% of the packaging material can be recycled, making it an eco-friendly solution for your business network.
High Performance
The rack-mount size metal case design combined with a safety certified internal power supply make the Switch the most robust product which is very cost-effective for a less than 16 user environment. Featuring non-blocking switching architecture, TL-SF1016DS forwards and filters packets at full wire-speed for maximum throughput. And IEEE 802.3x flow control for Full Duplex mode and backpressure for Half Duplex mode alleviate the traffic congestion and make TL-SF1016DS work reliably.
TP-LINK Green Technology
This new generation The TL-SF1016DS Fast Ethernet Switch features the latest innovative energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network. It also complies with the EU'S RoHS, prohibiting the use of certain hazardous materials. Besides, 70% of the packaging material can be recycled.
Easy to Use
The auto features of this fast ethernet switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (10 or 100 Mbps) and intelligently adjusts for compatibility and optimal performance.
Product Description TP-Link TL-SF1016DS - switch - 16 ports - rack-mountable
Device Type Switch - 16 ports
Enclosure Type Rack-mountable
Subtype Fast Ethernet
Ports 16 x 10/100
MAC Address Table Size 8K entries
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), packet filtering, store and forward
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3x
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 29.4 cm x 18 cm x 4.4 cm
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 16-Port 10/100...
£31.68
