TP LINK 16-Port Gigabit Switch
£55.57
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 16 10/100/1000 Mbps ports
  • Innovative energy-efficient technology saves power up to 40%
  • Supports MAC address self-learning, auto MDI/MDIX and auto negotiation
  • Plug & Play design
  • Type: Gigabit Ethernet
  • Ports: 16
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: No
Product codes
The TL-SG1016D 16-port gigabit switch provides an easy way to make the transition to gigabit Ethernet. All 16 ports support auto MDI/MDIX, no need to worry about the cable type, simply plug and play. Moreover, with the innovative energy-efficient technology, the TL-SG1016D can save up to 40% of the power consumption, making it an eco-friendly solution for your business network.
Product Description TP-Link TL-SG1016D 16-Port Gigabit Switch - switch - 16 ports - unmanaged
Device Type Switch - 16 ports - unmanaged
Subtype Gigabit Ethernet
Ports 16 x 10/100/1000
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 29.4 cm x 18 cm x 4.4 cm
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 16-Port Gigabi...
£55.57
