TP LINK 2.4G 15dBi 2x2 MIMO Sector Antenna
£132.06
Delivery:
Key features
  • High gain directional operation, wide coverage, ideal for Point to Multi-Point connections.
  • Easy installation, seamlessly integrated with the Pharos Base Station MIMO technology for higher throughput
  • Weatherproof design provides protection in harsh environments
Product codes
Outdoor omni-directional antenna TL-ANT2415D operates in the 2.4-2.5 GHz band and provides 15dBi omni-directional operation, which largely extends the wireless range and delivers much better wireless performance. The antenna offers the N female connector guaranteeing wider compatibility with most of the wireless equipments. Also, the weather proof design ensures that it can work normally for various demanding outdoor solutions.
The Outdoor Omni-Directional Antenna emits a powerful amplified signal over a 360 degree radius, delivering a strong multidirection signal from an Access Point or a Bridge. If you have multiple locations or buildings where you would like to integrate your wireless network, simply place the TL-ANT2415D in between the buildings with your Acess Point. It is most effective when placed at the top of buildings.
Easy To Use
Installation of the TL-ANT2415D is simple and straight forward. It is compatible with most wireless devices (Access Points, Routers, Bridges and Network Adapters) on the market with removable external antennas.
TP-Link TL-ANT2415MS - antenna
Antenna
13.3 cm x 5.7 cm x 70 cm
3.5 kg
Intended For
Wi-Fi
Aerial Placing / Mounting
Outdoor, pole mount
Compatibility
802.11 b/g/n
Frequency Range
2.3 - 2.7 GHz
Gain
15 dBi
Directivity
Directional
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 2.4G 15dBi 2x2...
£132.06
