TP LINK 2.4GHz 9dBi Indoor Omni-directional Antenna
Key features
  • Very easy to install
  • No software required
  • RP-SMA female connector
  • Works with device with RP-SMA male connector
Product codes
Indoor omni-directional antenna TL-ANT2409CL operates in the 2.4-2.5 GHz band and provides 9dBi omni-directional operation, which largely extends the wireless range and delivers much better wireless performance. The antenna offers the RP-SMA female connector guaranteeing wider compatibility with most of the wireless equipments.
Replacing your Wi-Fi antenna with TL-ANT2409CL will significantly increase the range and strength of your Wi-Fi signal. This quality built omni-directional antenna is a direct replacement for the antenna that comes standard with your router, access point. Because it is omni-directional, no aiming is equired - it can send and receive Wi-Fi in all directions.
Product Description TP-Link TL-ANT2409CL - antenna
Product Type Antenna
Aerial Placing / Mounting Indoor
Frequency Range 2.4 GHz
Gain 9 dBi
Directivity Omni-directional
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 2.4GHz 9dBi In...
