TP LINK 20000mAh Power Bank
£35.73
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High capacity of 20000mAh
  • Holds more charges, eg. 4.8 charges for iPhone XS
  • 2.1A Turbo Recharge could reach full capacity with much less time
  • Li-polymer battery greatly improves safety
  • The charger and your devices could be charged simultaneously
  • Stock Status: In Stock
Product codes
This high capacity charger has 2 high-speed charging ports which provide up to 2.1A adaptive power output. Powered by TP-Link Smart Charging technology, these output ports can intelligently recognize different products and are designed to be capable of delivering appropriate power for devices with large and tiny battery respectively.
Li-Polymer battery is thin and lightweight while it also improves safety, leading to its wide applications in premium digital devices. Compared to those using Li-ion battery, this power bank looks much sleeker and thinner. It is a portable charger that perfectly fits in your hand while working with your phone.
Housed in a portable design, TL-PB20000 is a high capacity 20000mAh power bank compatible with most of your digital devices. With full capacity, it can hold enough juice to fully charge your device multiple times.
Supporting 5V/2.1A recharging speed, TL-PB20000 can quickly recover from empty to full capacity, saving much time as models supporting 5V/1A do.
Product Description TP-Link TL-PB20000 power bank - Li-pol - USB
Product Type Power bank
Output Connector Type Total 2: USB - on cable: Micro-USB
Voltage Required 5 V
Voltage Provided 5 V
Max Electric Current 2.1 A
Battery Lithium polymer - 20000 mAh
Cables Micro-USB cable
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 20000mAh Power...
£35.73
