TP LINK 24-Port 10/100Mbps + 4-Port Gigabit + 2 SFP slot Smar...
TP LINK 24-Port 10/100Mbps + 4-Port Gigabit + 2 SFP slot Smart PoE S
£176.76
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Abundant Layer 2 features
  • Enterprise Level management features
  • Advanced QoS features
  • Type: Fast Ethernet
  • Ports: 24
  • POE: PoE
  • Stock Status: In Stock
Product codes
The T1500-28PCT provides 24 10/100Mbps ports that supports 802.3at/af-compliant PoE, with a total PoE power supply up to 180W, powerful and flexible enough for users to deploy wireless access points or IP-based network surveillance cameras. The switch also comes equipped with 4 10/100/1000Mbps RJ45 ports and 2 combo SFP slots, expanding your network flexibly. In addition, it provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features.
TP-LINK Smart PoE Switch T1500-28PCT is a cost-effective product solution for the small and medium business. T1500-28PCT has useful security features. The Storm Control feature protects against Broadcast, Multicast and Unknown unicast Storm. Quality of Service (QoS, L2 to L4) provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive layer 2 switch, TP-LINK smart PoE switch T1500-28PCT provides you the ideal access-edge solution.
Product Description TP-Link Smart PoE Switch T1500-28PCT - switch - 24 ports - rack-mountable
Device Type Switch - 24 ports
Enclosure Type Rack-mountable 1U
Subtype Fast Ethernet
Ports 24 x 10/100 (PoE) + 2 x SFP + 4 x 10/100/1000
Power Over Ethernet (PoE) PoE
PoE Budget 192 W
Performance Bandwidth: 12.8 Gbps , Forwarding performance: 9.5 Mpps
Capacity Active VLANs: 512
MAC Address Table Size 8K entries
Jumbo Frame Support 9KB
Routing Protocol IGMPv2, IGMP, IGMPv3
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Features Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, manageable, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), SSH support, fanless, Management Information Base (MIB), Class of Service (CoS), Loopback, DiffServ Code Point (DSCP) support
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 22 cm x 4.4 cm
System Requirements UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows Vista / XP, Microsoft Windows 7 / Windows 8
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 24-Port 10/100...
£176.76
