TP LINK 300Mbps Wireless N 3G Router
£30.30
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with UMTS/HSPA/EVDO USB modems, tested in the field
  • 3G/WAN failover guarantees an 'always-online' Internet connection
  • Supports PPPoE, dynamic IP, Static IP, PPTP, L2TP cable Internet access
  • SST technology dramatically increases link robustness and stability
  • CCA technology enhances your signal stability by automatically avoiding channel conflicts
  • Wireless security encryption easily at the push of the QSS button
  • Type: Wireless router
  • Connection Type: DSL (Cable)
  • Standards: Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g + 1 more
  • Speed: 300Mbps
  • Rackmount or External: External
Product codes
Share the freedom of 3G/4G! The TL-MR3420 3G/4G Wireless N Router allows users to share a 3G/4G mobile broadband connection with family and friends via wired or wireless connections. By connecting a 3G/4G USB modem to the routers, a Wi-Fi hotspot is instantly established, via which multiple devices can access the Internet and share data and applications wirelessly.
Enjoy 3G/4G Wireless Sharing
TL-MR3420 features blazing 4G speeds and backward compatible with 3G modems, allowing users to share a 3G/4G mobile broadband with family and friends via wired or wireless connection.
Tests in the Field-High Compatibility
Compatibility is the most important aspect to consider when you're selecting a 3G/4G router. To ensure the best compatibility between our routers and the modem you would use with the router, TP-LINK has made certain that our 3G/4G Routers are compatible with the ISPs in the regions in which they are sold. We have teams around the globe continually testing our Routers with newly emerged modems to ensure that end users can feel confident that their routers will operate flawlessly where they live and work.
Comprehensive 3G/4G and WAN Connection Backup Strategy
The TL-MR3420 stands out with its 3G/ 4G and WAN connection back-up, which keeps users online when one connection fails. TP-LINK's 3G/4G Router provides users with both 3G/4G Preferred and WAN Preferred back-up modes, while other brands provide one or the other. This brings users a high degree of flexibility when users are setting up the networks with considering connection costs and length of downtime.
Wireless N Speed & Range
Complying with the IEEE 802.11n standard, the TL-MR3420 can establish a wireless network with transmission speeds of up to 300Mbps, while mitigating data loss over long distances and through obstacles in a small office or a large apartment, even in a steel-and-concrete building. Above all, users can easily pick up their wireless network's signal at longer distances from the router, where with legacy 11g products they would have to be much closer.
WPA / WPA2 Encryptions -Advanced Security
In order to safeguard user`s Wi-Fi networks, WEP encryption is no longer strong enough. The TL-MR3420 provides WPA/WPA2 encryptions (Both Personal and Enterprise),created by the WI-FI Alliance, promoting interpretabilities and security for WLAN, to protect against almost any threat that the Internet or intruders may harbor.
* All above information apply to TL-MR3420 version 2.0 ONLY.*
Product Description TP-Link TL-MR3420-V1 - wireless router - 802.11b/g/n - desktop
Device Type Wireless router - 4-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz
Data Transfer Rate 300 Mbps
Network / Transport Protocol TCP/IP, ICMP/IP, PPPoE
Routing Protocol Static IP routing
Remote Management Protocol HTTP
Features Firewall protection, DMZ port, NAT support, auto-uplink (auto MDI/MDI-X), dynamic DNS server, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, MIMO technology, virtual server support, DHCP server
Compliant Standards IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Dimensions (WxDxH) 17.4 cm x 11.1 cm x 3 cm
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 300Mbps Wirele...
£30.30
