TP LINK 300Mbps Wireless N Gigabit ADSL2+ Modem Router
SALE PRICE! - WAS £39.10
Key features
  • All-in-one device: ADSL2+ modem, NAT router, 4-Gigabit-port switch and wireless N access point
  • 300 Mbps wireless speed and Gigabit Ethernet ports, ideal for multiple HD video streams
  • Versatile connectivity: ADSL, Ethernet WAN or 3G/4G modem for multiple Internet connection types
  • One USB 2.0 port for storage sharing, printer sharing, FTP server, Media server and 3G/4G modem
Product codes
TP-LINK's TD-W8970 300Mbps Wireless N Gigabit ADSL2+ Modem Router is an incredibly robust all-in-one device allowing users to access high-speed internet connections and share them wirelessly at blazing 300Mbps wireless speeds or by using one of its 4 Gigabit LAN ports. With 2 multifunctional USB ports, users can share printers, files and media across the local network or the internet. What's more, this All-in-one device allows for two different connection types: ADSL, or Ethernet WAN, giving users the flexibility to access the Internet whichever method is most convenient.
Clear up your desktop!
The TD-W8970 does the work of several networking devices packed into one sleek device. With an ADSL2+ modem, NAT router and 300Mbps wireless access point, this device eliminates the need to purchase multiple devices to access and share a high-speed internet connections.
Full Gigabit Ports - More Power to You
With 300Mbps 802.11n wireless and 4 Gigabit LAN ports, the TD-W8970 is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming.
2 USB Sharing Ports - Easy Sharing
Using the TD-W8970's two multi-functional USB 2.0 ports, users can share printers, files and media either throughout the network at home with several different computers or even away, using the device's FTP server functions so that you never have to part with your files.
Interchangeable LAN/WAN Port - Versatile Connectivity
The TD-W8970 supports ADSL or Ethernet WAN connections (EWAN) that allow users to have the flexibility of different Internet connections among ADSL, cable or fiber modem using its interchangeable LAN/WAN port. This unique feature makes it easier when users need to change to fiber or cable services when necessary.
IPv6 Ready
This device supports IPv6, which is foundational to the next generation Internet and enables a range of new services and improved user experiences.
Virtually Impregnable
The ability to support up to 10 IPsec VPN tunnels simultaneously gives TD-W8970 users the flexibility to setup a virtual private network, to guarantee network security and take advantage of network access whether at home or away, for work or simply to access files from their local networks.
IP QoS - Efficient Bandwidth Control
IP QoS allows network administrators to allot a specific amount of available bandwidth to each network connected device simply by identifying it by its IP address, ensuring that those devices with critical tasks always have enough bandwidth and preventing any one device from hoarding bandwidth from the rest of the users on the network.
Header / Manufacturer TP-LINK Technologies
Header / Product Line TP-LINK
Type Wireless router
Header / Model TD-W8970
Header / Packaged Quantity 1
Modem / Digital Signaling Protocol ADSL2+
Networking / Form Factor (FE) Desktop
Speed 300 Mbps
Networking / Integrated Switch 4-port switch
Networking / Connectivity Technology Wireless
Miscellaneous / Encryption Algorithm 128-bit AES, 128-bit WEP, 192-bit AES, 256-bit AES, 64-bit WEP, DES, IKE, MD5, SHA-1, SSL, Triple DES, WPA, WPA-PSK, WPA2, WPA2-PSK
System Requirements / OS Required Apple MacOS, Linux, Microsoft Windows 2000 / NT, Microsoft Windows 98 Second Edition, Microsoft Windows Vista / XP / 7, Novell NetWare, UNIX
Networking / Network / Transport Protocol DDNS, DHCP, DNS, IPoA, IPSec, L2TP, PPPoA, PPPoE, PPTP
Standards Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Networking / Remote Management Protocol HTTP, SNMP 1, SNMP 2c, Telnet
Modem / Protocols & Specifications ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.994.1 (G.hs), ITU G.995.1
Header / Compatibility Mac, PC
Networking / Routing Protocol Static IP routing
Dimensions & Weight / Height 3.25 cm
Dimensions & Weight / Width 24.3 cm
Dimensions & Weight / Depth 16.06 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 300Mbps Wirele...
