TP LINK 300Mbps Wireless N USB VDSL2 Modem Router
£43.44
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • All-in-one: VDSL2/ADSL2+ modem, NAT router and wireless access point in one device provides a one-stop networking solution
  • Wireless N speed up to 300 Mbps makes it ideal for heavy bandwidth consuming or interruption sensitive applications like online gaming, Internet calls and even the HD video streaming
  • IP based bandwidth control allows administrators to determine how much bandwidth is allocated to each PC
  • Versatile connectivity: VDSL/ADSL, Ethernet WAN or UMTS/LTE
  • Modem for multiple Internet connection types
  • Guest network access provides secure Wi-Fi access for guests sharing your home or office network
  • Supports the Internet Protocol IPv6 to future-proof your network
  • Wi-Fi on/off switch lets you simply turn the wireless radio on or off
  • Parental control allows parents or administrators to establish restricted access policies for children or staff
  • Supports up to 10 IPSec VPN tunnels simultaneously
  • Easily setup an encrypted security connection at a push of WPS button
Product codes
TP-LINK's 300 Mbps Wireless N USB VDSL2 modem router TD-W9970 is an incredibly robust all-in-one device allowing users to access high-speed Internet connection via VDSL/ADSL, 3G/4G modem or Ethernet WAN (EWAN) using its interchangeable LAN/WAN port and share it wirelessly at 300 Mbps wireless 802.11n speeds. With its multifunctional USB port, users can share printers, files & media across the local network or share files & media via the Internet. Moreover, it supports the Internet protocol IPv6 to future-proof your network.
TP-Link TD-W9970 - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2+, VDSL2
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, DHCP, DNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP
Firewall protection, DMZ port, NAT support, IGMP snooping, traffic shaping, print server, MAC address filtering, IPv6 support, URL filtering, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Dead Peer Detection (DPD), virtual server support, FTP server, port triggering, DHCP relay, DNS relay, port grouping, Guest Zone support
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
19.5 cm x 13 cm x 3.6 cm
Microsoft Windows Vista / XP / 7 / 8 / 8.1
Customer reviews
Accessories
Network Adaptors
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 300Mbps Wirele...
£43.44
