TP LINK 32-bit Gigabit PCIe Adapter
£9.94
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Wake-on-LAN supporting
  • Auto-negotiation and auto MDI/MDIX
  • Supports IEEE802.3x flow control for full-duplex mode and backpressure for half-duplex mode
  • Supports IEEE 802.1p layer 2 priority encoding and IEEE802.1q VLAN tagging
  • Supports power down/link down power saving
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Form Factor: Plug-in card
  • Compatibility: PC
  • Type: Network adapter
Product codes
TG-3468 10/100/1000Mbps Gigabit PCIe Network Adapter is a highly integrated and cost-effective 32-bit Gigabit PCIe Ethernet Adapter which is fully compliant with IEEE 802.3, IEEE 802.3u and IEEE 802.3ab specifications.
The PCIe Gigabit Network Adapter TG-3468 is a high performance adapter designed for the high-speed PCI Express Bus Architecture. Designed to support 10/100/1000Mbps network speed Auto-Negotiation, 802.3x flow control and Wake-on-LAN technology. TG-3468 Gigabit PCIe Network Adapter is a highly integrated and cost-effective Gigabit Ethernet adapter which is a good selection to upgrade your network.
Product Description TP-Link TG-3468 - network adapter
Device Type Network adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express x1
PCI Specification Revision PCIe 1.0a
Ports Gigabit Ethernet
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 1 Gbps
Network / Transport Protocol TCP/IP, CSMA/CD
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
System Requirements Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 32-bit Gigabit...
£9.94
