TP LINK 4-Port SafeStream Gigabit Broadband VPN Router
£62.25
Delivery:
Standard: 1-3 working days
Key features
  • High-security VPN capabilities
  • Abundant security features
  • Safety minded enterprise investments
  • Type: Router
  • Connection Type: DSL (Cable)
  • Standards: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Speed: [N/A]
  • Rackmount or External: External
Product codes
TL-R600VPN, TP-LINK's SafeStream Gigabit Broadband VPN Router, supports Gigabit Ethernet connections on both WAN and LAN ports which guarantee high-speed wired connectivity. What's more, it integrates multiple VPN protocols, high-security and high-performance VPN capabilities, which enable employees' remote connections to their main offices as secure as if they were in the main office. Besides, TL-R600VPN's abundant security strategies such as SPI Firewall, Dos Defense and IP-MAC Binding help protect your network against most known attacks. TL-R600VPN is an ideal partner for small offices, which need cost-effective and reliable VPN solutions.
Product Description TP-Link SafeStream TL-R600VPN - router - desktop
Device Type Router - 4-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet
Performance VPN throughput: 20 Mbps , NAT throughput: 120 Mbps
Capacity IPSec VPN tunnels: 20 , PPTP VPN tunnels: 16 , Concurrent sessions: 10000
Network / Transport Protocol TCP/IP, PPTP, L2TP, ICMP/IP, IPSec, PPPoE, FTP, DHCP
Routing Protocol Static IP routing
Remote Management Protocol HTTP, TFTP
VoIP Protocols H.323
Features DMZ port, NAT support, VPN support, ARP support, Syslog support, DoS attack prevention, MAC address filtering, VPN passthrough, IP address filtering, firmware upgradable, SNTP support, Access Control List (ACL) support, virtual server support, DHCP server, bandwidth control, port triggering, Stateful Packet Inspection Firewall (SPIF), IP-MAC binding, DHCP client
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, UPnP
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 20.9 cm x 12.6 cm x 2.6 cm
System Requirements UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/ME/XP/Vista/7
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 4-Port SafeStr...
£62.25
