TP LINK 5-Port 10/100Mbps Desktop Switch With 4-Port PoE
£31.74
48 in stock
Delivery:
Standard: 1-3 working days
Key features
  • With four PoE ports, transfers data and power on one single cable
  • Working with IEEE 802.3af compliant PDs, expands your network
  • Supports PoE Power up to 15.4 W for each PoE port
  • Supports PoE Power up to 41 W for all PoE ports
  • Plug and play, no configuration and installation required
  • Up to 250 m data and power transmission under Extend Mode specially designed for surveillance system
  • Type: Fast Ethernet
  • Ports: 5
  • Managed: No
  • POE: PoE
Product codes
TL-SF1005LP is a 5 10/100 Mbps ports unmanaged switch that requires no configuration and provides 4 PoE (Power over Ethernet) ports. It can automatically detect and supply power with all IEEE 802.3af compliant Powered Devices (PDs). In this situation, the electrical power is transmitted along with data in one single cable allowing you to expand your network to where there are no power lines or outlets, where you wish to fix devices such as APs, IP Cameras or IP Phones, etc.
Product Description TP-Link TL-SF1005LP - V1 - switch - 5 ports - unmanaged
Device Type Switch - 5 ports - unmanaged
Subtype Fast Ethernet
Ports 5 x 10/100 (4 PoE)
Power Over Ethernet (PoE) PoE
PoE Budget 41 W
Performance Packet forwarding rate: 0.744 Mpps , Switching capacity: 1 Gbps
MAC Address Table Size 2K entries
Jumbo Frame Support 2KB
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, fanless, metal housing, priority mode, extend mode, security slot (Kensington security lock compatible), Intelligent Power Management
Compliant Standards IEEE 802.3af, IEEE 802.3x
Dimensions (WxDxH) 10 cm x 9.8 cm x 2.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£31.74
