We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
TL-SG1005LP is a professional 5-port Gigabit switch with 4 PoE+ ports. The total 40 W PoE power budget for the four PoE ports opens up a wide range of applications, such as surveillance for offices, dormitories, and small businesses. It is fully compatible with IP cameras, access points, IP phones, computers, printers, and more. The interior components of TL-SG1005LP are protected by high-quality metal casing to ensure a long product life.
Product Description | TP-Link TL-SG1005LP - V1 - switch - 5 ports - unmanaged | Device Type | Switch - 5 ports - unmanaged | Subtype | Gigabit Ethernet | Ports | 5 x 10/100/1000 (4 PoE+) | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 40 W | Performance | Packet forwarding rate: 7.44 Mpps , Switching capacity: 10 Gbps | MAC Address Table Size | 2K entries | Jumbo Frame Support | 16KB | Routing Protocol | IGMP | Features | Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, Quality of Service (QoS), fanless, DiffServ Code Point (DSCP) support | Compliant Standards | IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at | Dimensions (WxDxH) | 9.98 cm x 9.8 cm x 2.5 cm |
General | |
Enclosure Type | Desktop, wall-mountable |
PoE Budget | 40 W |
Expansion / Connectivity | |
Interfaces | 5 x 1000Base-T RJ-45 4 ports (PoE+) - 30 W |
Power | |
Power Device | External power adapter |
Power Provided | DC 53.5 V - 0.81 A |
Power Consumption Operational | 47.5 Watt |
Miscellaneous | |
Compliant Standards | Plug and Play, FCC, RoHS |
Dimensions & Weight | |
Width | 9.98 cm |
Depth | 9.8 cm |
Height | 2.5 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
