As the flagship 2.5G products, the 5/8-Port desktop switches with 5/8x 2.5-Gigabit ports unlock the highest performance of your Multi-Gig bandwidth and devices, and provide up to 25/40 Gbps of switching capacity. Auto-negotiation 3-speed (100Mb/1G/2.5G) connections sense the link speeds and intelligently adjust for compatibility and optimal performance for all your devices, including 2.5G NAS, 2.5G PCIe adapter, gaming console, VR gaming, 2.5G Wi-Fi 6 AP, 4K video, desktop, and more.
Product Description | TP-Link TL-SG105-M2 - V1 - switch - 5 ports - unmanaged | Device Type | Switch - 5 ports - unmanaged | Subtype | 2.5 Gigabit Ethernet | Ports | 5 x 100/1000/2.5G | Performance | Switching capacity: 25 Gbps , Packet forwarding rate: 18.6 Mpps | Capacity | Packet buffer size: 1.5 MB | MAC Address Table Size | 16K entries | Jumbo Frame Support | 10000 bytes | Features | Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, Quality of Service (QoS), fanless, metal housing, DiffServ Code Point (DSCP) support | Compliant Standards | IEEE 802.1p, IEEE 802.3x | Dimensions (WxDxH) | 20.9 cm x 12.6 cm x 2.6 cm |
General | |
Enclosure Type | Desktop, wall-mountable |
Status Indicators | Power, status |
Expansion / Connectivity | |
Interfaces | 5 x 100/1000/2.5G RJ-45 |
Power | |
Power Device | External power adapter |
Power Provided | DC 12 V - 1 A |
Miscellaneous | |
Compliant Standards | Plug and Play, FCC, RoHS |
Dimensions & Weight | |
Width | 20.9 cm |
Depth | 12.6 cm |
Height | 2.6 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
