TP LINK 8-port 10/100 mini Desk Switch
£7.39
44 in stock
Delivery:
Standard: 1-3 working days
  • Type: Fast Ethernet
  • Ports: 8
  • Data Transfer Rate: 100Mbps
  • Managed: No
  • POE: No
Product codes
TL-SF1008D 8-port 10/100Mbps Fast Ethernet Switch provides 8 10/100Mbps Auto-Negotiation RJ45 ports. All ports support Auto MDI/MDIX function, eliminating the need for crossover cables or Uplink ports. The Switch is Plug-and-Play and each port can be used as general ports or Uplink ports and can be simply plugged into a server, a hub or a switch, using straight cable or crossover cable.
The TP-LINK TL-SF1008D 8-port 10/100M Fast Ethernet Switch provides you with a low-cost, easy-to-use, high-performance, seamless and standard upgrade to improve your old network to a 100Mbps network. It will boost your network performance up to full duplex data transfer. Its wire-speed switching that forwards packets can be as fast as the speed that your network delivers those packets to them.
Product Description TP-Link TL-SF1008D 8-Port 10/100Mbps Desktop Switch - switch - 8 ports
Device Type Switch - 8 ports
Subtype Fast Ethernet
Ports 8 x 10/100
MAC Address Table Size 1K entries
Features Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3x
Power (50/60 Hz)
Dimensions (WxDxH) 14 cm x 8.5 cm x 3.3 cm
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 8-port 10/100...
£7.39
