TP LINK 8-Port Gigabit Desktop Switch
£27.78
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 8 10/100/1000Mbps Auto-Negotiation RJ45 ports supporting Auto-MDI/MDIX
  • Green Ethernet technology saves power consumption
  • IEEE 802.3x flow control provides reliable data transfer
  • Steel housing, desktop or wall-mounting design
  • Support 802.1p/DSCP QoS and IGMP Snooping function
  • Plug and play, with no configuration needed
  • Type: Gigabit Ethernet
  • Ports: 8
Product codes
The TP-Link 8-Port 10/100/1000Mbps Desktop Switch provides you an easy way to make the transition to Gigabit Ethernet. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality. Plug and Play design, with no configuration required, makes the product easy to use. Moreover, TL-SG108S adopts lower power consumption design. With the innovative energy-efficient technology, the TL-SG108S can save power consumption, making it an eco-friendly solution for your home or office network.
Product Description TP-Link TL-SG108S - switch - 8 ports
Device Type Switch - 8 ports
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000
Performance Forwarding performance: 11.9 Mpps
MAC Address Table Size 4K entries
Jumbo Frame Support 16KB
Features Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, Quality of Service (QoS), Green Ethernet, fanless
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3x, IEEE 801.1p
Dimensions (WxDxH) 15.8 cm x 10.1 cm x 2.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£27.78
