TP LINK 8-Port Gigabit Easy Smart Switch with 4-Port PoE
£68.74
Delivery:
Standard: 1-3 working days
Key features
  • 8 10/100/1000 Mbps RJ-45 ports
  • With 4 PoE ports, data and power can be transferred on one single cable
  • Provides network monitoring, traffic prioritization and VLAN features
  • Simple network setup on top of plug-and-Play connectivity
  • Web-based user interface simplifies configuration
  • Type: Gigabit Ethernet
  • Ports: 8
  • Managed: Yes
  • POE: PoE
  • Stock Status: In Stock
Product codes
The TL-SG108PE is an 8-port Gigabit Easy Smart switch with 4 PoE ports, represents a powerful upgrade from an unmanaged switch. It is designed specifically for small businesses that require simple network management and PoE function. The TL-SG108PE can connect and power up to four PoE devices, such as wireless access points (APs), IP cameras, and IP phones. Through its web-based user interface and management utility, the TL-SG108PE offers a variety of useful features, including network monitoring, traffic prioritization, and enhanced QoS. Additionally, with port-based, tag-based and MTU VLAN, TL-SG108PE can improve security and meet more network segmentation requirements.
Product Description TP-Link Easy Smart TL-SG108PE - switch - 8 ports - smart
Device Type Switch - 8 ports - smart
Subtype Gigabit Ethernet
Ports 4 x 10/100/1000 (4 PoE) + 4 x 10/100/1000
Power Over Ethernet (PoE) PoE
PoE Budget 55 W
Performance Forwarding performance: 11.9 Mpps
Capacity Virtual interfaces (VLANs): 32
MAC Address Table Size 4K entries
Jumbo Frame Support 15KB
Features Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, Quality of Service (QoS), Cable Diagnostics Function, fanless, loop prevention, DiffServ Code Point (DSCP) support, 1.5MB packet buffer, Storm Control, Link Aggregation
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 801.1p
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows Vista / XP / 7, Windows 8 / 8.1, Windows 10
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK 8-Port Gigabit...
£68.74
