The TL-SG1008MP is an 8-Port Gigabit Desktop/Rack mountable Switch with all 8 ports supporting the PoE+ standard. It provides a simple way to expand a wired network by transferring power and data over a single Ethernet Cable. With a total power budget of 126W, up to 30W per port, TL-SG1008MP can power more high-powered devices such as wireless Access Points (APs), IP Cameras or IP Phones. Moreover, with innovative energy-efficient technology, the TL-SG1008MP can save up to 75% of the power consumption, making it an eco-friendly solution for your business network.
All 8 ports of TL-SG1008MP support Power over Ethernet Plus (PoE+) standard which can automatically detect and supply power to any IEEE 802.3af/at compliant device(s). In this situation, the electrical power is transmitted along with data in a single cable, allowing you to expand your network where there are no electrical cables or outlets, where you wish to fix devices such as APs, IP Cameras or IP Phones.
Product Description | TP-Link TL-SG1008MP - switch - 8 ports - unmanaged - rack-mountable | Device Type | Switch - 8 ports - unmanaged | Enclosure Type | Rack-mountable | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 (PoE+) | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 126 W | Performance | Bandwidth: 16 Gbps | MAC Address Table Size | 4K entries | Jumbo Frame Support | 16KB | Features | Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, half duplex mode, full duplex mode, Quality of Service (QoS), Jumbo Frames support, DiffServ Code Point (DSCP) support, 1.5MB packet buffer, Back Pressure Support, 1 fan | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 801.1p, IEEE 802.3at | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 29.4 cm x 18 cm x 4.4 cm | Manufacturer Warranty | Limited lifetime warranty |
General | |
Enclosure Type | Desktop, rack-mountable |
Built-in Devices | Led panel |
Status Indicators | Power, 1000M device connected, PoE, link/activity |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-T RJ-45 PoE+ - 30 W |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 140.67 Watt |
Miscellaneous | |
Included Accessories | Rubber feet |
Rack Mounting Kit | Included |
Compliant Standards | Plug and Play, FCC, RoHS |
Dimensions & Weight | |
Width | 29.4 cm |
Depth | 18 cm |
Height | 4.4 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
