TP LINK AC1300 Wireless Dual Band PCI Express Adapter
£48.67
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easy installation - upgrade your desktop system easily by plugging the Archer T6E Wi-Fi adapter into an available PCI-E slot
  • Hi-Speed Wi-Fi - up to 1300Mbps Wi-Fi speeds (867Mbps on 5GHz band or 400Mpbs on 2.4GHz band)
  • 802.11ac dual band - 3 times faster than the 802.11n standard, perfect for hi-intensity network usage
  • Backward compatibility - wWith support for 802.11 a/b/g/n standards
  • Broad wireless range - 2 external antennas ensure a greater range of Wi-Fi connection and stability
  • Wired / Wireless: Wireless
  • Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • Compatibility: PC
  • Type: Network adapter
  • Stock Status: In Stock
Product codes
Easy Installation – Upgrade your desktop system easily by plugging the Archer T6E Wi-Fi adapter into an available PCI-E slot
Hi-Speed Wi-Fi – Up to 1300Mbps Wi-Fi speeds (867Mbps on 5GHz band or 400Mpbs on 2.4GHz band)
802.11ac Dual Band – 3 times faster than the 802.11n standard, perfect for hi-intensity network usage
Backward Compatibility – With support for 802.11 a/b/g/n standards
Broad Wireless Range – 2 external antennas ensure a greater range of Wi-Fi connection and stability
802.11ac - The Next Generation of Wi-Fi
TP-LINK's Archer T6E supports the next generation Wi-Fi standard - IEEE 802.11ac, offering transfer rates that are 3 times faster than wireless N speeds. Easily upgrade your desktop system by simply slotting the Wi-Fi adapter into an available PCI-E slot.
AC1300 – Selectable Dual Band Speeds 867/400Mbps
The Archer T6E provides high-speed Wi-Fi of up to 867Mbps over 5GHz, perfect for HD video streaming and lag-free online gaming. Additionally, the 2.4GHz 400Mbps Wi-Fi band is ideal for standard network/internet usage such as web surfing.
Heat Sink for Better Stability
The Heat Sink helps to dissipate heat generated by the adapter, which in turn increases performance and improves stability. What’s more, lower temperatures ensure an increased adapter lifespan.
External Antennas
External antennas for easy alignment to achieve the best signal.
Operating System
Supports Windows 8.1/8/7/XP 32/64bit.
Easy to Install
A friendly user interface Utility on a CD for simple installation.
Advanced Security
WPA/WPA2 encryption standards ensure your wireless connection is safe from intruders.
Product Description TP-Link Archer T6E - network adapter
Device Type Network adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express
Dimensions (WxDxH) 2.15 cm x 11.52 cm x 12.08 cm
Data Link Protocol 802.11ac
Data Transfer Rate 1300 Mbps
Frequency Band 2.4 GHz, 5 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac
System Requirements Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK AC1300 Wireles...
£48.67
