TP LINK AC1750 Wireless Dual Band Gigabit Router - V2.0
£78.18
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Supports 802.11ac standard - the next generation of Wi-Fi
  • Dual USB ports - easily share printers, files or media with your friends or family locally or over the Internet
  • Guest network access provides secure Wi-Fi access for guests sharing your home or office network
Product codes
V2.0
802.11ac - The Next Generation of Wi-Fi
TP-LINK's Archer C7 comes with the next generation Wi-Fi standard - 802.11ac, 3 times faster than wireless N speeds and delivering a combined wireless data transfer rate of up to 1.75Gbps. With 1.3Gbps wireless speeds over the crystal clear 5GHz band and 450Mbps over the 2.4GHz band, the Archer C7 is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
1.75Gbps Dual Band Connections for Lag-Free Work and Entertainment
The Archer C7 operates over both the 2.4GHz and 5GHz bands, ensuring amazing wireless performance. Simultaneous Dual Band offers you the flexibility of two dedicated networks - with multiple times the bandwidth for your needs. Simple tasks like sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
6 Antennas for Fully Expanded Coverage
With 3 external 5dBi antennas serving the 5GHz band and 3 internal antennas serving the 2.4GHz band combined with higher quality antenna technology, you can maintain high speeds across greater distances. This provides you with incredible wireless coverage and reliability from anywhere in your large home or office.
Full Gigabit Wired Connections for Ultrafast Data Transfer Speeds
With one gigabit WAN port and four gigabit LAN ports, speeds can be up to 10× faster than standard Ethernet connections. The Archer C7 is a powerful hub to support a robust and extremely fast wired network.
Dual Multifunctional USB Ports for Storage and Sharing
With the two multi-functional USB 2.0 ports, you can share printers, files and media with different devices through your local network or via the ftp server while away from home.
Guest Network
Guest Network Access provides secure Wi-Fi access for guests sharing your home or office network.
Easy Set-up
Included in the resource CD, TP-LINK's optimized configuration utility can help users complete the entire software installation and wireless network settings in just a few minutes.
IPv6 Supported
Archer C7 supports IPv6, which is foundational to the next generation Internet and enables a range of new services and improved user experiences.
TP-Link Archer C7 AC1750 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.75 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DDNS
Routing Protocol
Static IP routing
Firewall protection, DMZ port, Stateful Packet Inspection (SPI), print server, MAC address filtering, IPv6 support, parental control, Wi-Fi Multimedia (WMM) support, virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, FTP server, bandwidth control, IPv4 support, port triggering, dynamic IP mode, DHCP client
IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
24.3 cm x 16.06 cm x 3.25 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT / 2000 / XP, Microsoft Windows Vista / 7 / 8
Customer reviews
Accessories
Network Adaptors
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK AC1750 Wireles...
£78.18
