TP Link Archer AX73 V1 Wireless Router - 802.11a/b/g/n/ac/ax...
TP Link Archer AX73 V1 Wireless Router - 802.11a/b/g/n/ac/ax - Desktop
£153.15
Delivery:
Standard: 1-3 working days
Key features
  • Full Gigabit WiFi for 8K Streaming - up to 5400 Mbps of dual-band WiFi for faster browsing, streaming, and downloading, all at the same time
  • Fully Featured Wi-Fi 6 - equipped with the top structure of 4T4R and HE160 on the 5 GHz band to enable 4.8 Gbps ultra-fast connections
  • Up to 4x More Capacity - supports MU-MIMO and OFDMA to reduce congestion and quadruple the average throughput
  • Extensive Coverage - 6× high-performance antennas with beamforming technology ensure broad coverage
  • HomeShield - TP-Link's premium security service keeps your home network safe with cutting-edge features for network and IoT protection
  • More vents, long-lasting performance - contemporary design that also acts as a vent area to unleash the full power of performance
  • Type: Wireless router
  • Standards: IEEE 802.11n, Fast Ethernet, IEEE 802.11a, Ethernet + 5 more
Product codes
Gigabit WiFi for 8K Streaming – 5400 Mbps WiFi for faster browsing, streamings, and downloading, all at the same time.
Fully Featured Wi-Fi 6 – Equips with the top structure of 4T4R and HT160 on the 5 GHz band to enable 4.8 Gbps ultra-fast connection.
Connect 200+ Devices – Supports MU-MIMO and OFDMA to reduce congestion and quadruple the average throughput.‡**
Extensive Coverage – 6× antennas and Beamforming ensure broad coverage.
HomeShield – TP-Link's premium security services keep your home network safe with cutting-edge features for network and IoT protection.*
More Vents, Less Heat – Improved vents area unleash the full power of the whole machine.
USB Sharing – 1× USB 3.0 port enables easy media sharing and private cloud building.
Easy Setup – Set up the router in minutes with Tether app.
Product Description TP-Link Archer AX73 - V1 - wireless router - 802.11a/b/g/n/ac/ax - desktop
Device Type Wireless router - 4-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band 2.4 GHz / 5 GHz
Network / Transport Protocol PPTP, L2TP, PPPoE, FTP, DHCP, DDNS, IPv4, IPv6
Routing Protocol IGMP, static IP routing
Features NAT support, IGMP snooping, Stateful Packet Inspection (SPI), DFS support, URL filtering, parental control, Access Point operational mode, firmware upgradable, Access Control List (ACL) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), FTP server, static IP mode, port forwarding, reset button, Apple Time Machine compatible, port triggering, dynamic IP mode, IP-MAC binding, DHCP client, IGMP proxy, beamforming technology, dual band, router mode, Airtime Fairness, 4x4 MU-MIMO technology, DMZ support, PPTP server, Orthogonal Frequency Division Multiple Access (OFDMA), OpenVPN server, IPTV support, WPS button
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Dimensions (WxDxH) 27.25 cm x 14.72 cm x 4.92 cm
Weight 1.49 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£153.15
