With combined speeds of up to 3150Mbps, the Archer C3150 easily handles demanding activities at the same time. The router uses enhanced Wi-Fi technology to create a faster, stronger, more reliable wireless network for your home. With the Archer C3150, lag, dropped connections, and dead zones will become a thing of the past. The Archer C3150 boasts a powerful combination of a Broadcom NitroQAM technology and 4-Stream technology. This provides the speed and performance that you need to support your most demanding online applications, including simultaneous 4K streaming and online gaming. The Archer C3150 does more than just create faster Wi-Fi, it helps your devices achieve optimal performance by making communication more efficient. With MU-MIMO technology, the Archer C3150 can provide four simultaneous data streams, allowing all connected devices to achieve faster speeds.
Archer C3150 can support many devices when you invite friends to your large house to entertain. It can maintain multiple simultaneous HD streaming, online gaming and other content consumption without lag. The Archer C3150 can provide a maximized coverage and enable your devices to stay covered, near or far as it. Don't let your mobile lifestyle stop the streaming and enjoy your home party. The Archer C3150 features a powerful processor. This unlocks the full potential of MU-MIMO and 4-Stream technologies, helping your dual band router maximize its performance potential. Four high-performance dual band antennas and high-powered amplifiers help create a strong, far-reaching network for your home. Beamforming technology focuses the Wi-Fi transmission in the direction of your connected devices, concentrating the signal where you need it the most. This allows you to enjoy fast, stable Wi-Fi in every part of your home, as well as on the patio, by the pool, and even in the yard.
Product Description | TP-Link Archer C3150 - wireless router - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 3167 Mbps | Network / Transport Protocol | PPTP, L2TP, PPPoE, DHCP, DDNS | Features | VPN support, dynamic DNS server, print server, IPv6 support, parental control, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, reset button, bandwidth control, IPv4 support, DHCP client, MU-MIMO technology, SmartConnect Technology, beamforming technology, Broadcom NitroQAM technology, WDS bridge | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac | Dimensions (WxDxH) | 26.38 cm x 19.78 cm x 3.73 cm | System Requirements | UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS |
Processor | 1.4 GHz |
Expansion / Connectivity | |
Interfaces | LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A |
Aerial | |
Aerial | External detachable |
Antenna Qty | 4 |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
OS Required | UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 |
Dimensions & Weight | |
Width | 26.38 cm |
Depth | 19.78 cm |
Height | 3.73 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
