TP LINK Auranet EAP330 Radio Access Point 802.11a/b/g/n/ac
Key features
  • Speeds of up to 1.9Gbps over concurrent dual band 802.11ac Wi-Fi with MIMO and TurboQAM technologies
  • Airtime Fairness, Beamforming, and Band Steering technologies provide optimal RF performance for business-level applications
  • Link aggregation joins two gigabit Ethernet ports to break the bottleneck in network backhaul capacity
  • Captive portal provides a convenient method for guest authentication
  • Power over Ethernet (802.3at) support and simple mounting design allow for flexible deployment and convenient installation
Product codes
The combination of 802.11ac Wi-Fi and MIMO and TurboQAM technology allows EAP series devices to offer an unbeatable Wi-Fi experience. Broadcom enterprise-class chipsets offers amazing enterprise-grade performance, resulting in longer spans of stable operation and larger client capacities. The dedicated high-power amplifier, professional antenna, and well-designed RF shield ensure great wireless performance. Link aggregation combines two wired connections to double throughput and provide a redundant link for Internet access. Airtime Fairness improves total Wi-Fi throughput by limiting access time for low speed devices.
Band Steering pushes dual-band devices to the wider and faster 5GHz band, improving overall network performance, especially in high client density environments. Beamforming technology achieves superior Wi-Fi bandwidth utilization and increases Wi-Fi range by creating efficient, highly targeted Wi-Fi connections Captive portal provides one convenient method of authentication for Wi-Fi guests. A captive portal requires users to perform certain actions before network access is allowed. The required action must be verified by an external portal server or customized database by the administrator, which can be simply viewing and agreeing to an acceptable use policy, or entering a user ID and password.
Product Description TP-Link Omada EAP330 - radio access point
Device Type Radio access point
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Included Accessories Wall mounting kit, ceiling mounting kit
OS Required Microsoft Windows Vista / XP / 7 / 8, Windows 10
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 22.05 cm x 19.35 cm x 3.65 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK Auranet EAP330...
