TP LINK AV1000 2port Gigabit Starter Kit
Key features
  • Ideal for slick streaming and smooth downloads
  • 2 gigabit ports for maximum connectivity
  • Plug-and-Play, no configuration required
  • Reduce power consumption by up to 85%
Product codes
Comes with advanced HomePlug AV2 technology, TL-PA7020 KIT provides users with high-speed data transfer rates of up to 1000 Mbps, which is ideal for bandwidth intensive applications such as multiple HD/3D/4K video streaming, online gaming and large file transfers.
With 2 gigabit Ethernet ports, TL-PA7020 KIT can simultaneously connect up to 2 wired-only devices. This makes the TL-PA7020 KIT the perfect home entertainment companion. Connect any 2 devices from smart TVs and games consoles to NAS boxes and computers to the Internet at the same time. Just plug the Ethernet cable into the powerline and away you go!
Connect a powerline adapter to the router; plug another powerline adapter into a wall socket in another room, and connect it to your Internet enabled device via Ethernet - and you're done!
TP-Link TL-PA7020 KIT - Starter Kit - bridge - wall-pluggable
Bridge
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0
Data Transfer Rate
1 Gbps
Routing Protocol
IGMPv2, IGMP, IGMPv3
Quality of Service (QoS), Type of Service (ToS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0
AC 230V (50 Hz)
12.3 cm x 6.8 cm x 3 cm
Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7, Windows 8, Windows 8.1
United Kingdom
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK AV1000 2port G...
